Adds the specified port as a loopback port for the specified member VLAN.
| vlan_name | Specifies the name of the member VLAN to which you want to add the loopback port. |
| port | Specifies the port that serves as the loopback port. |
N/A.
If two or more member VLANs have overlapping ports (where the same ports are assigned to both VLANs), each of the member VLANs with overlapping ports must have a dedicated loopback port.
The loopback port can be added to the member VLAN when the member VLAN is created, or you can use this command to add the loopback port at a later time.
The following example adds port 2:1 as a loopback port for the member VLAN leafvlan:
configure leafvlan vlan-translation add loopback-port 2:1
This command is available on all platforms that support the VLAN Translation feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
